Adding date to the output file's name
Started by Ari
Ari
Adding date to the output file's name   12 February 2014, 22:06
Hi Andrew,
Small question
I created a batch file to automate the netscanner by using windows schedule task. Now the problem is that i would like to have the date in the output file. I found the command and if i type it manually in the command file it works great:
start /wait netscan.exe /config:D:\Tools\Netscan\test.xml /auto:D:\Logs\Netscan\date_%yyyy%%mm%%dd%.xml
Output file:
date_20140212
If i start the command by using batch i get on the output file without the date:
date_
did i miss something?
Thanks for help.
Regards
Ari
Re: Adding date to the output file's name   13 February 2014, 09:59
Hi Ari,
This is because the percent signs are stripped from a batch file text and are treated as environment variables.
In a batch file, you need to double the percent signs
/auto:D:\Logs\Netscan\date_%%yyyy%%%%mm%%%%dd%%.xml
Ari
Re: Adding date to the output file's name   13 February 2014, 18:49
Hi Andrew,
thanks a lot that works perfect!
regards,
Ari
