Remote Registry
The application can read values from the Windows registry on remote devices, provided the Remote Registry service is running on the target. Choose Options → Remote Registry from the menu.
Remote Registry dialog
Three registry items configured for retrieval.
The dialog shows five columns: Item Name, Root, Registry Key, Parameter Name and Local Value. Several predefined entries are included, such as the DirectX version, CPU model and registered Windows owner.
Configuration
When creating a new entry, specify the registry root (HKEY_LOCAL_MACHINE, HKEY_USERS or HKEY_CURRENT_USER), the key path and the parameter name. Click the browse button (…) next to either field to open the Registry Browser, a two-panel interface that lets you navigate the registry tree on the left and view values on the right.
Action modes
The Action dropdown determines how the key path is interpreted:
Read a value from one key: simple path
Reads the named value from the exact key path specified. This is the fastest mode for a single, known location.
Read a value from multiple keys: wildcards allowed
Expands wildcards (* and ?) in the key path to match multiple keys, then reads the named value from each. For example, HARDWARE\DESCRIPTION\System\CentralProcessor\* reads the value from every CPU subkey. Results are returned as a list of key: value pairs.
Check if the key exists
Simply reports whether the specified key is present. The parameter name is not used.
Alternative paths
You can use the bracket syntax to specify alternative path segments separated by a vertical bar. For example:
SOFTWARE\[Microsoft|Policies\Microsoft]\Windows\CurrentVersion
The scanner will try each alternative and proceed with the first valid one. This is useful when a key can exist in different locations on 32-bit vs 64-bit systems.
checking a specific registry setting fleet-wide
Suppose you need to verify that a particular security policy is applied to all workstations. Create a registry query pointing to the relevant key (e.g. HKEY_LOCAL_MACHINE\SOFTWARE\Policies\...) and the value name. After scanning, the column will show the value on each device, making it easy to spot machines where the policy is missing or incorrect.
